I want to use a sketch up component to be able to modify the size or the position of many windows at one time. I tried to draw one window then to create a component and then do copy paste, but when I went in the OS inspector there was only one subsurface created. Moreover when I saved, quited and reopened my model, all the windows had disappeared exept the first one.
Do you know if we can use Sketch up component ?
thanks
Philippine
