I would like to be able to use fenced code blocks delimited by ``` instead of having to rely on 4-spaces indent.
Askbot seems to be using python-markdown2 internally so the change should be easy enough
This is a code block
with multiple lines of code, and it isn't being rendered correctly.
Resources:
- https://askbot.org/en/question/16779/is-askbot-having-code-highlighting/
- https://python-markdown.github.io/extensions/fenced_code_blocks/
