Hello,
I'm currently using OS 2.9.1 and model a residential building in which I applied a GSHP (which should be reversible, that means it provides heating and cooling) and connected it successfully to my secondary radiant heating loop.
However, when I add a water-to-water Heat Pump cooling object and create a secondary radiant cooling loop, no cooling is provided. Temperature Setpoint managers are applied for both -heating and cooling. How can I fix that problem?
GSHP loop with water-to-water Heat Pump (heating and cooling)
Radiant heating loop (heating coil of heat recovery ventilation)
Radiant cooling loop --> no cooling in the final results!
The closest solution I found and implemented successfully was similar to: https://unmethours.com/question/4823/how-to-model-gshp-with-radiant-floor-heating-in-openstudio/ where GSHP water-to-water for heating and water-to-air for cooling was used. But I would prefer if cooling is as well provided by a water-to-water object.
