No cooling load for district loads
Hello,
I am trying to run a simple model for envelope evaluation. I used Ieal load and the only load is showing in energy plus results is the District heating load, no cooling load even with the 2A climate zoen (arizona). Does anybody know a solution for this?
Hello,
I am trying to run a simple model for envelope evaluation. evaluation using openStudio. I used Ieal Ideal load and the only load is showing in energy plus results is the District heating load, no cooling load even with the 2A climate zoen (arizona). Does anybody know a solution for this?
Hello,
I am trying to run a simple model for envelope evaluation using openStudio. I used Ideal load and the only load is showing in energy plus results is the District heating load, no cooling load even with the 2A climate zoen (arizona). Does anybody know a solution for this?
Hello,
