Hallo all,
I would like to set an "outdoor air flow rate fraction schedule" based on the outside temperature. The purpose is to enable the natural ventilation when the external temperature reaches a certain value. Then I need to have two different schedules, for winter and summer.
In the schedule label, I can add a new object. Then, I have to select the schedule type and I should select temperature. Is It internal or external temperature?
Is there some other parameter/schedule that I have to set? Thanks A.
