I'm trying to apply radiance daylighting measure in my model but it failed.
I'm using openstudio 2.9.1. if I click on the advance output tab it shows bellow information. if anybody knows the reasons please help me out to solve the problem.
Standard Output:
[21:20:34.384661 ERROR] :/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb failed with message C:/Users/Md Muin Uddin/BCL/1e3cfef8-b051-4e60-8bb0-ed2d29d4f45f/77b56312-1bff-49a4-91e8-64db8264357c/measure.rb:1320: syntax error, unexpected '.'
t_radGlareSensorViews[space_name]&.each do |sensor, v|
C:/Users/Md Muin Uddin/BCL/1e3cfef8-b051-4e60-8bb0-ed2d29d4f45f/77b56312-1bff-49a4-91e8-64db8264357c/measure.rb:1418: syntax error, unexpected keyword_rescue, expecting keyword_end
rescue Exception => e
^ in :/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:339:in load'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:339:inapply_measure'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:109:in block in apply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:67:ineach_index'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:67:in apply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/jobs/run_os_measures.rb:68:inperform'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/run.rb:285:in step'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/run.rb:232:inrun'
:/openstudio_cli.rb:975:in execute'
:/openstudio_cli.rb:763:inexecute'
:/openstudio_cli.rb:1746:in '
eval:116:ineval'
eval:116:in require_embedded_absolute'
eval:101:inblock in require'
eval:95:in each'
eval:95:inrequire'
eval:3:in '
[21:20:34.384661 ERROR] Found error in state 'os_measures' with message [":/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb failed with message C:/Users/Md Muin Uddin/BCL/1e3cfef8-b051-4e60-8bb0-ed2d29d4f45f/77b56312-1bff-49a4-91e8-64db8264357c/measure.rb:1320: syntax error, unexpected '.'\n t_radGlareSensorViews[space_name]&.each do |sensor, v|\n ^\nC:/Users/Md Muin Uddin/BCL/1e3cfef8-b051-4e60-8bb0-ed2d29d4f45f/77b56312-1bff-49a4-91e8-64db8264357c/measure.rb:1418: syntax error, unexpected keyword_rescue, expecting keyword_end\n rescue Exception => e\n ^ in :/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:339:inload'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:339:in apply_measure'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:109:inblock in apply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:67:in each_index'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:67:inapply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/jobs/run_os_measures.rb:68:in perform'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/run.rb:285:instep'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/run.rb:232:in run'\n:/openstudio_cli.rb:975:inexecute'\n:/openstudio_cli.rb:763:in execute'\n:/openstudio_cli.rb:1746:in'\neval:116:in eval'\neval:116:inrequire_embedded_absolute'\neval:101:in block in require'\neval:95:ineach'\neval:95:in require'\neval:3:in'::/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:639:in rescue in apply_measure'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:645:inapply_measure'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:109:in block in apply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:67:ineach_index'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:67:in apply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/jobs/run_os_measures.rb:68:inperform'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/run.rb:285:in step'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/run.rb:232:inrun'\n:/openstudio_cli.rb:975:in execute'\n:/openstudio_cli.rb:763:inexecute'\n:/openstudio_cli.rb:1746:in '\neval:116:ineval'\neval:116:in require_embedded_absolute'\neval:101:inblock in require'\neval:95:in each'\neval:95:inrequire'\neval:3:in `'"]}
Standard Error: :/ruby/2.2.0/gems/json_pure-2.2.0/lib/json/version.rb:4: warning: already initialized constant JSON::VERSION :/ruby/2.2.0/json/version.rb:3: warning: previous definition of VERSION was here :/ruby/2.2.0/gems/json_pure-2.2.0/lib/json/version.rb:5: warning: already initialized constant JSON::VERSION_ARRAY :/ruby/2.2.0/json/version.rb:4: warning: previous definition of VERSION_ARRAY was here :/ruby/2.2.0/gems/json_pure-2.2.0/lib/json/version.rb:6: warning: already initialized constant JSON::VERSION_MAJOR :/ruby/2.2.0/json/version.rb:5: warning: previous definition of VERSION_MAJOR was here :/ruby/2.2.0/gems/json_pure-2.2.0/lib/json/version.rb:7: warning: already initialized constant JSON::VERSION_MINOR :/ruby/2.2.0/json/version.rb:6: warning: previous definition of VERSION_MINOR was here :/ruby/2.2.0/gems/json_pure-2.2.0/lib/json/version.rb:8: warning: already initialized constant JSON::VERSION_BUILD :/ruby/2.2.0/json/version.rb:7: warning: previous definition of VERSION_BUILD was here :/ruby/2.2.0/gems/json_pure-2.2.0/lib/json/common.rb:100: warning: already initialized constant JSON::NaN :/ruby/2.2.0/json/common.rb:99: warning: previous definition of NaN was here :/ruby/2.2.0/gems/json_pure-2.2.0/lib/json/common.rb:102: warning: already initialized constant JSON::Infinity :/ruby/2.2.0/json/common.rb:101: warning: previous definition of Infinity was here :/ruby/2.2.0/gems/json_pure-2.2.0/lib/json/common.rb:104: warning: already initialized constant JSON::MinusInfinity :/ruby/2.2.0/json/common.rb:103: warning: previous definition of MinusInfinity was here :/ruby/2.2.0/gems/json_pure-2.2.0/lib/json/common.rb:129: warning: already initialized constant JSON::UnparserError :/ruby/2.2.0/json/common.rb:128: warning: previous definition of UnparserError was here
run.log:
eval:116:ineval'
eval:95:in each'
eval:95:inrequire'
eval:3:in '
