I have updated my IDF to E+ 9.4, I've updated all exchange handlers adding the "state" variable, but now it throws the following warning too many times:
* Warning * Data Exchange API: You seem to already have tried to get an Actuator Handle on this one. * ~~~ * Occurred for componentType='SCHEDULE:COMPACT', controlType='SCHEDULE VALUE', uniqueKey='N1LAB_TSP'. * ~~~ * The getActuatorHandle function will still return the handle (= 21) but caller should take note that there is a risk of overwritting.
I check the output results and compare with the results in E+ 9.3 and are not the same. I don't understand where is the problem, Any ideas.
