Hello everyone! I am modeling a solar cooling system in EnergyPlus and while running the simulation I've got this severe error: * Severe * PsyRhoAirFnPbTdbW: RhoAir (Density of Air) is calculated <= 0 [-9.04677]. * ~~~ * pb =[101100.00], tdb=[-312.09], w=[0.0000000]. * ~~~ * Routine=CorrectZoneHumRat, During Warmup, Environment=DSDAYTANGIER COOLING 0.4%, at Simulation time=08/21 00:12 - 00:13 * Fatal * Program terminates due to preceding condition. I also got a warning that the calculated cooling load is zero, and also the water heater's Recovery Efficiency and Energy Factor could not be calculated during the test for standard ratings. I tried to hard size the cooling coil but the results are the same. If anyone could help I'll be grateful. For more details you could find my IDF file in this link: https://drive.google.com/file/d/15HFwuj9s5h5tGAAyysOLbcL4D75Nv1uP/view?usp=sharing
