Hi there, I am facing a problem with a measure using a resource folder with a subfolder "data" containing several csv files. If I run the model using the measure, it does not copy the subfolder "data" with the csv files into the temp folder. Do you have an idea what the problem could be here? Obviously the measure fails because it does not find the needed csv files.
Thanks for your help.
