Exterior wall r-value PAT
I used alternative the R-values for exterior wall system in PAT, but after running it shows an error the insulation thickness of the construction wall exceeds the requested R-value. I didn't set R-value for my wall system in PAT. Is this something predefined based on the given climate? Any help that how I could run this? I saw the link below which someone asked a similar question, however the reply refers to two links which do not work.
https://unmethours.com/question/28267/how-to-change-building-insulation-thickness-using-pat-measure/
