Set Output Table To IP Units Error
I ran the Set Output Table To IP Units and got to the following error:
* Severe * <root>[ComponentCost:LineItem][Interior Ceiling_TakeOff][line_item_type] - "Constuction" - Failed to match against any enum values.
I duplicated the measure and edited. After changing in the measure the word "Constuction" for "Construction" and running the measure it solve the error.
If you have the same problem your can do the same.
