Blockquote
Processing Reporting Measures.
Applying UnmetLoadHoursTroubleshooting
Result: Fail
Error: undefined method getDesignLoopExitTemperature' for #<OpenStudio::Model::SizingPlant:0x000001892c556688>
C:/Users/Dell/AppData/Local/Temp/osmodel-1605677165-0/resources/measures/UnmetLoadHoursTroubleshooting/measure.rb:291:inblock in plant_loop_temp_vs_setpoints'
C:/Users/Dell/AppData/Local/Temp/osmodel-1605677165-0/resources/measures/UnmetLoadHoursTroubleshooting/measure.rb:274:in each'
C:/Users/Dell/AppData/Local/Temp/osmodel-1605677165-0/resources/measures/UnmetLoadHoursTroubleshooting/measure.rb:274:inplant_loop_temp_vs_setpoints'
C:/Users/Dell/AppData/Local/Temp/osmodel-1605677165-0/resources/measures/UnmetLoadHoursTroubleshooting/measure.rb:558:in run'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:514:inapply_measure'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:109:in block in apply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:ineach_index'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:in apply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/jobs/run_reporting_measures.rb:105:inperform'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:in step'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:234:inrun'
:/openstudio_cli.rb:973:in execute'
:/openstudio_cli.rb:763:inexecute'
:/openstudio_cli.rb:1757:in <main>'
eval:149:ineval'
eval:149:in require_embedded_absolute'
eval:123:inblock in require'
eval:117:in each'
eval:117:inrequire'
eval:3:in `<main>'
Blockquote
