I am simulating a small model with radiance daylighting measure in Openstudio 2.7. While running the simulation, the following error comes
Initializing workflow.
Processing OpenStudio Measures.
Applying RadianceMeasure
Result: Fail
Error: undefined method each' for #<RadianceMeasure:0x0001a2c7cd67a0>
C:/Users/prasanth/AppData/Local/Temp/OpenStudioApp.b11096/resources/measures/RadianceMeasure 1/measure.rb:1320:inblock (2 levels) in parseResults'
C:/Users/prasanth/AppData/Local/Temp/OpenStudioApp.b11096/resources/measures/RadianceMeasure 1/measure.rb:1252:in each'
C:/Users/prasanth/AppData/Local/Temp/OpenStudioApp.b11096/resources/measures/RadianceMeasure 1/measure.rb:1252:inblock in parseResults'
C:/Users/prasanth/AppData/Local/Temp/OpenStudioApp.b11096/resources/measures/RadianceMeasure 1/measure.rb:1248:in times'
C:/Users/prasanth/AppData/Local/Temp/OpenStudioApp.b11096/resources/measures/RadianceMeasure 1/measure.rb:1248:inparseResults'
C:/Users/prasanth/AppData/Local/Temp/OpenStudioApp.b11096/resources/measures/RadianceMeasure 1/measure.rb:1203:in runSimulation'
C:/Users/prasanth/AppData/Local/Temp/OpenStudioApp.b11096/resources/measures/RadianceMeasure 1/measure.rb:2466:inrun'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/measure.rb:467:in apply_measure'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/measure.rb:74:inblock in apply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/measure.rb:32:in each_index'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/util/measure.rb:32:inapply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/jobs/run_os_measures.rb:52:in perform'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/run.rb:269:instep'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.3/lib/openstudio/workflow/run.rb:216:in run'
:/openstudio_cli.rb:920:inexecute'
:/openstudio_cli.rb:709:in execute'
:/openstudio_cli.rb:1686:in<main>'
eval:110:in eval'
eval:110:inrequire_embedded_absolute'
eval:95:in block in require'
eval:89:ineach'
eval:89:in require'
eval:2:in<main>'
Info: Begin Encoding.default_external = US-ASCII
Info: Begin Encoding.default_internal =
Info: Radiance multiprocessing features are not supported on Windows.
Info: Using 1 core(s) for Radiance jobs
Info: Found Radiance at: C:\openstudio-2.7.0\Radiance
Info: Found Perl at: C:\openstudio-2.7.0\Perl\perl\bin
Info: Found EnergyPlus at: C:\openstudio-2.7.0\EnergyPlus\energyplus.exe
Info: Radiance version: NREL 5.0.a.12 (by googs 2016.10.04) based on RADIANCE 5.0 Official Release by G. Ward
Info: Radiance binary dir: C:\openstudio-2.7.0\Radiance\bin
Info: Radiance library dir: C:\openstudio-2.7.0\Radiance\lib
Info: Translating OpenStudio 2.x model to Radiance format...
Info: OpenStudio CLI version: 2.7.0.544f363db5
Info: Working directory: 'C:\Users\prasanth\AppData\Local\Temp\OpenStudioApp.b11096\resources\run\000_RadianceMeasure 1\radiance'
Info: epw2wea "C:\Users\prasanth\AppData\Local\Temp\OpenStudioApp.b11096\resources\files\IND_Chennai-Madras.432790_ISHRAE.epw" wx\in.wea
Info: added glare sensor 'numeric\Space_1_Glare_Sensor_1.glr' to calculation points
Info: Passing 102 calculation points to Radiance
Info: Computing daylight coefficient matrices
Info: oconv materials\materials.rad model.rad > octrees\model_dc.oct
Info: Computing view matrix for uncontrolled windows (WG0)
Info: oconv materials\materials.rad model.rad skies\dc_sky.rad skies\dc_sky.rad > octrees\model_WG0.oct
Info: type numeric\merged_space.map | rcontrib -ab 10 -ad 65536 -as 512 -dj 1 -dp 1 -dt 0 -dc 1 -lw 1.52e-005 -I+ -fo -e MF:1 -f tregenza.cal -b tbin -bn Ntbins -faa -o output\dc\WG0.vmx -m skyglow octrees\model_WG0.oct
Info: Daylight coefficient matrices computed.
Info: Performing annual daylight simulation(s)
Info: gendaymtx -m 1 "wx\in.wea" > annual-sky.mtx
Info: dctimestep output\dc\WG0.vmx annual-sky.mtx | rmtxop -fa -c 47.4 120 11.6 - > output\ts\WG0.ill
Info: Creating whole-building daylight results file...
Info: INFO: Model has 0 controlled window groups
Info: Finalizing output...
Info: rmtxop -fa output\ts\WG0.ill -t | getinfo - > output\merged_space.ill
Info: Parsing daylighting results
Failed.
Your help is really appreciated.
