Actuate coil capacities with EMS?
Hi, there,
I need some help on a case where I want to change the cooling and heating coil capacities dynamically under some condition (through EMS program). Systems are fixed-sized in idf, I've tried the Unitary HVAC Design Heating Capacity and Unitary HVAC Design Cooling Capacity, but they're not working. Is it feasible to actuate capacities in E+? Any suggestions?
Thanks!
Test file if you're interested:
  1. With Unitary HVAC Design Capacity actuators
  2. Without actuators
Hi, there,
Thanks!
Hi, there,
Thanks!
