Program Version,EnergyPlus, Version 9.3.0-baff08990c, YMD=2020.11.03 11:19, * Warning * CheckEnvironmentSpecifications: SimulationControl specified doing design day simulations, but no design environments specified. * ~~~ * ...No design environment results produced. For these results, add appropriate SizingPeriod:* objects for your simulation. * Warning * ProcessScheduleInput: Schedule:Constant="ALWAYS OFF DISCRETE", Blank Schedule Type Limits Name input -- will not be validated. * Warning * ProcessScheduleInput: Schedule:Constant="ALWAYS ON CONTINUOUS", Blank Schedule Type Limits Name input -- will not be validated. * Warning * GetHTSurfaceData: Surfaces with interface to Ground found but no "Ground Temperatures" were input. * ~~~ * Found first in surface=FACE 0 * ~~~ * Defaults, constant throughout the year of (18.0) will be used. * Severe * RoofCeiling:Detailed="FACE 116", Vertex size mismatch between base surface :FACE 116 and outside boundary surface: FACE 35 * ~~~ * The vertex sizes are 6 for base surface and 7 for outside boundary surface. Please check inputs. * Severe * RoofCeiling:Detailed="FACE 117", Vertex size mismatch between base surface :FACE 117 and outside boundary surface: FACE 194 * ~~~ * The vertex sizes are 7 for base surface and 6 for outside boundary surface. Please check inputs. * Severe * RoofCeiling:Detailed="FACE 126", Vertex size mismatch between base surface :FACE 126 and outside boundary surface: FACE 203 * ~~~ * The vertex sizes are 14 for base surface and 16 for outside boundary surface. Please check inputs. * Severe * RoofCeiling:Detailed="FACE 180", Vertex size mismatch between base surface :FACE 180 and outside boundary surface: FACE 259 * ~~~ * The vertex sizes are 6 for base surface and 4 for outside boundary surface. Please check inputs. * Severe * RoofCeiling:Detailed="FACE 194", Vertex size mismatch between base surface :FACE 194 and outside boundary surface: FACE 117 * ~~~ * The vertex sizes are 6 for base surface and 7 for outside boundary surface. Please check inputs. * Severe * RoofCeiling:Detailed="FACE 195", Vertex size mismatch between base surface :FACE 195 and outside boundary surface: FACE 274 * ~~~ * The vertex sizes are 7 for base surface and 6 for outside boundary surface. Please check inputs. * Severe * RoofCeiling:Detailed="FACE 203", Vertex size mismatch between base surface :FACE 203 and outside boundary surface: FACE 126 * ~~~ * The vertex sizes are 16 for base surface and 14 for outside boundary surface. Please check inputs. * Severe * RoofCeiling:Detailed="FACE 204", Vertex size mismatch between base surface :FACE 204 and outside boundary surface: FACE 283 * ~~~ * The vertex sizes are 14 for base surface and 16 for outside boundary surface. Please check inputs. * Severe * RoofCeiling:Detailed="FACE 259", Vertex size mismatch between base surface :FACE 259 and outside boundary surface: FACE 180 * ~~~ * The vertex sizes are 4 for base surface and 6 for outside boundary surface. Please check inputs. * Severe * RoofCeiling:Detailed="FACE 260", Vertex size mismatch between base surface :FACE 260 and outside boundary surface: FACE 339 * ~~~ * The vertex sizes are 6 for base surface and 4 for outside boundary surface. Please check inputs. * Severe * RoofCeiling:Detailed="FACE 274", Vertex size mismatch between base surface :FACE 274 and outside boundary surface: FACE 195 * ~~~ * The vertex sizes are 6 for base surface and 7 for outside boundary surface. Please check inputs. * Severe * RoofCeiling:Detailed="FACE 275", Vertex size mismatch between base surface :FACE 275 and outside boundary surface: FACE 352 * ~~~ * The vertex sizes are 7 for base surface and 6 for outside boundary surface. Please check inputs. * Severe * RoofCeiling:Detailed="FACE 283", Vertex size mismatch between base surface :FACE 283 and outside boundary surface: FACE 204 * ~~~ * The vertex sizes are 16 for base surface and 14 for outside boundary surface. Please check inputs. * Severe * RoofCeiling:Detailed="FACE 339", Vertex size mismatch between base surface :FACE 339 and outside boundary surface: FACE 260 * ~~~ * The vertex sizes are 4 for base surface and 6 for outside boundary surface. Please check inputs. * Severe * RoofCeiling:Detailed="FACE 352", Vertex size mismatch between base surface :FACE 352 and outside boundary surface: FACE 275 * ~~~ * The vertex sizes are 6 for base surface and 7 for outside boundary surface. Please check inputs. * Severe * RoofCeiling:Detailed="FACE 353", Vertex size mismatch between base surface :FACE 353 and outside boundary surface: FACE 428 * ~~~ * The vertex sizes are 7 for base surface and 6 for outside boundary surface. Please check inputs. * Severe * RoofCeiling:Detailed="FACE 428", Vertex size mismatch between base surface :FACE 428 and outside boundary surface: FACE 353 * ~~~ * The vertex sizes are 6 for base surface and 7 for outside boundary surface. Please check inputs. * Severe * RoofCeiling:Detailed="FACE 35", Vertex size mismatch between base surface :FACE 35 and outside boundary surface: FACE 116 * ~~~ * The vertex sizes are 7 for base surface and 6 for outside boundary surface. Please check inputs. * Fatal * GetSurfaceData: Errors discovered, program terminates. ...Summary of Errors that led to program termination: ..... Reference severe error count=18 ..... Last severe error=RoofCeiling:Detailed="FACE 35", Vertex size mismatch between base surface :FACE 35 and outside boundary surface: FACE 116 *** Warning: Node connection errors not checked - most system input has not been read (see previous warning). *** Fatal error -- final processing. Program exited before simulations began. See previous error messages. *** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors. *** EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors. *** EnergyPlus Terminated--Fatal Error Detected. 4 Warning; 18 Severe Errors; Elapsed Time=00hr 00min 0.69sec
