Hello,
I am trying to run a SDK openstudio version. I am not that familiar with it and if I have missed something please do point it out. So currently I have a osm file that has been created using a json which has rooms. In the osm I see the space and space types. I created a osw file with the create_typical_doe_building and I got some errors regarding setstandardbuilding type so I added a few measures that I found online. Please see the osw file below.
The conditioned zones error has me stuck. I am not trying to do any modifications for the inputs right now so just want the osm file to run and create a report. The osm file does run just fine in the application if the thermal zones are added but in the code the measure should do the same so I am not sure whats happening.
{ "seed_file": "all_rac_basic_model.osm", "file_paths": [ "./weather" ], "measure_paths" : [ "./measures" ], "weather_file": "USA_CA_San.Francisco.Intl.AP.724940_TMY3.epw", "steps": [ { "arguments": { "__SKIP__": false }, "measure_dir_name": "Set Climate Zone from Weather Data" }, { "arguments": { "__SKIP__": false }, "measure_dir_name": "Space Type and Construction Set Wizard" }, { "arguments": { "__SKIP__": false }, "measure_dir_name": "CreateandAssignThermalZonesforUnassignedSpaces" }, { "arguments": { "__SKIP__": false }, "measure_dir_name": "Set Thermostat Schedules" }, { "arguments": { "__SKIP__": false }, "measure_dir_name": "CreateTypicalDOEBuilding" } ] }
Thank you
