I am trying to model windows in EnergyPlus. I have edited the IDF in SketchUp to detail the building and window design. I get the following IDF Parsing Error (shown in picture) for all 8 window surfaces when I try to open the IDF in the IDF Editor. I have checked that all have a semi-colon after the last vertex definition.
I have also run into this severe error to check the tilt of the window. I created the windows in SketchUp, on the base surface within the EnergyPlus Zone.
Any help to sort out this error is greatly appreciated!
* Severe * checkSubSurfAzTiltNorm: Outward facing angle of subsurface differs more than 90.0 degrees from base surface. * ~~~ * Subsurface="SOUTHWINDOW1" Tilt = 0.0 Azimuth = 299.7 * ~~~ * Base surface="2F8F12" Tilt = 90.0 Azimuth = 180.0
