I am running the python EnergyPlus plugin option to run PythonPluginCustomSchedule.idf example file provided in the energyplus 9.4 packages. Although Output: Variable object is populated in the idf there is no .csv file of the outputs created. Is there a way to enable that or is this option still not available?
I came across this concern when running energyplus in Eppy as well.
Kind regards,
