Hello, I'm hoping to model an absorption heat pump system for a design that has been made in BEopt. Is it possible to see the "black box" values of the design, such as the heat transfer in/out for the design?
I think I can make some basic calculations knowing the heat transfer of the design, and the temperatures (which are easily found), as well as details about the absorption heat pump (which I have).
Any help or suggestions would be appreciated!
