Hello, I have already tried the same model with OpenStudio Versions 2.7, 2.8 and 2.9. The model runs fine with EnergyPlus Simulations but fails as soon as Radiance Measure is applied. The added illuminance Map, Glare Sensor and the Daylight Controller fall inside a Thermal Zone as was required as I searched through a few previous questions that have been covered in the same forum. The link to the model is : https://drive.google.com/drive/folders/1VKUmDkpvndsyeUj_I_Q24cZ8W1bM3M4U?usp=sharing
Kindly help.
The Output shown on Simulation Window> Initializing workflow. Processing OpenStudio Measures. Applying RadianceMeasure Failed.
The Advanced Output
Standard Output:
[17:48:52.990200 ERROR] :/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb failed with message C:/Users/nycta/BCL/1e3cfef8-b051-4e60-8bb0-ed2d29d4f45f/77b56312-1bff-49a4-91e8-64db8264357c/measure.rb:1320: syntax error, unexpected '.'
t_radGlareSensorViews[space_name]&.each do |sensor, v|
C:/Users/nycta/BCL/1e3cfef8-b051-4e60-8bb0-ed2d29d4f45f/77b56312-1bff-49a4-91e8-64db8264357c/measure.rb:1418: syntax error, unexpected keyword_rescue, expecting keyword_end
rescue Exception => e
^ in :/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:339:in load'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:339:inapply_measure'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:109:in block in apply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:67:ineach_index'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:67:in apply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/jobs/run_os_measures.rb:68:inperform'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/run.rb:285:in step'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/run.rb:232:inrun'
:/openstudio_cli.rb:975:in execute'
:/openstudio_cli.rb:763:inexecute'
:/openstudio_cli.rb:1746:in '
eval:116:ineval'
eval:116:in require_embedded_absolute'
eval:101:inblock in require'
eval:95:in each'
eval:95:inrequire'
eval:3:in '
[17:48:52.991198 ERROR] Found error in state 'os_measures' with message [":/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb failed with message C:/Users/nycta/BCL/1e3cfef8-b051-4e60-8bb0-ed2d29d4f45f/77b56312-1bff-49a4-91e8-64db8264357c/measure.rb:1320: syntax error, unexpected '.'\n t_radGlareSensorViews[space_name]&.each do |sensor, v|\n ^\nC:/Users/nycta/BCL/1e3cfef8-b051-4e60-8bb0-ed2d29d4f45f/77b56312-1bff-49a4-91e8-64db8264357c/measure.rb:1418: syntax error, unexpected keyword_rescue, expecting keyword_end\n rescue Exception => e\n ^ in :/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:339:inload'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:339:in apply_measure'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:109:inblock in apply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:67:in each_index'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:67:inapply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/jobs/run_os_measures.rb:68:in perform'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/run.rb:285:instep'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/run.rb:232:in run'\n:/openstudio_cli.rb:975:inexecute'\n:/openstudio_cli.rb:763:in execute'\n:/openstudio_cli.rb:1746:in'\neval:116:in eval'\neval:116:inrequire_embedded_absolute'\neval:101:in block in require'\neval:95:ineach'\neval:95:in require'\neval:3:in'::/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:639:in rescue in apply_measure'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:645:inapply_measure'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:109:in block in apply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:67:ineach_index'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:67:in apply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/jobs/run_os_measures.rb:68:inperform'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/run.rb:285:in step'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/run.rb:232:inrun'\n:/openstudio_cli.rb:975:in execute'\n:/openstudio_cli.rb:763:inexecute'\n:/openstudio_cli.rb:1746:in '\neval:116:ineval'\neval:116:in require_embedded_absolute'\neval:101:inblock in require'\neval:95:in each'\neval:95:inrequire'\neval:3:in `'"]}
Standard Error: :/ruby/2.2.0/gems/json_pure-2.2.0/lib/json/version.rb:4: warning: already initialized constant JSON::VERSION :/ruby/2.2.0/json/version.rb:3: warning: previous definition of VERSION was here :/ruby/2.2.0/gems/json_pure-2.2.0/lib/json/version.rb:5: warning: already initialized constant JSON::VERSION_ARRAY :/ruby/2.2.0/json/version.rb:4: warning: previous definition of VERSION_ARRAY was here :/ruby/2.2.0/gems/json_pure-2.2.0/lib/json/version.rb:6: warning: already initialized constant JSON::VERSION_MAJOR :/ruby/2.2.0/json/version.rb:5: warning: previous definition of VERSION_MAJOR was here :/ruby/2.2.0/gems/json_pure-2.2.0/lib/json/version.rb:7: warning: already initialized constant JSON::VERSION_MINOR :/ruby/2.2.0/json/version.rb:6: warning: previous definition of VERSION_MINOR was here :/ruby/2.2.0/gems/json_pure-2.2.0/lib/json/version.rb:8: warning: already initialized constant JSON::VERSION_BUILD :/ruby/2.2.0/json/version.rb:7: warning: previous definition of VERSION_BUILD was here :/ruby/2.2.0/gems/json_pure-2.2.0/lib/json/common.rb:100: warning: already initialized constant JSON::NaN :/ruby/2.2.0/json/common.rb:99: warning: previous definition of NaN was here :/ruby/2.2.0/gems/json_pure-2.2.0/lib/json/common.rb:102: warning: already initialized constant JSON::Infinity :/ruby/2.2.0/json/common.rb:101: warning: previous definition of Infinity was here :/ruby/2.2.0/gems/json_pure-2.2.0/lib/json/common.rb:104: warning: already initialized constant JSON::MinusInfinity :/ruby/2.2.0/json/common.rb:103: warning: previous definition of MinusInfinity was here :/ruby/2.2.0/gems/json_pure-2.2.0/lib/json/common.rb:129: warning: already initialized constant JSON::UnparserError :/ruby/2.2.0/json/common.rb:128: warning: previous definition of UnparserError was here
run.log:
eval:116:ineval'
eval:95:in each'
eval:95:inrequire'
eval:3:in '
