Hello, I'm using the newest version openstudio sketchup plugin v1.0.1. However, all the functions under Reports are failed to work at all. As I ran the space type report in Sketchup 2019, the Ruby console showed the following lines:
Running Space Type Report Error occurred while running user script: Invalid argument @ rb_sysopen - "D:\Projects\Baohua_SpaceTypeReport.csv_.csv" (Errno::EINVAL)
["C:/Users/Dell/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/openstudio/user_scripts/Reports/SpaceType_Report.rb:221:in initialize'", "C:/Users/Dell/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/openstudio/user_scripts/Reports/SpaceType_Report.rb:221:inopen'", "C:/Users/Dell/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/openstudio/user_scripts/Reports/SpaceType_Report.rb:221:in run'", "C:/Users/Dell/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/openstudio/lib/PluginUserScriptRunner.rb:386:inrun_user_script'", "C:/Users/Dell/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/openstudio/lib/MenuManager.rb:950:in `block in add_user_script'"]
User script Space Type Report completed with errors
