Temperature Dataset of PNNL Models
Hello,
I asked a question regarding the Temperature Dataset of PNNL Models and found the answer of it on this link.
I can generate ".ESO" files now and get different outputs from the PNNL models. However, I cannot find Output:Variable,,Zone Mean Air Temperature,Hourly; in the Output:Variable section of the ".idf" file. Also, after simulation, only ".ESO" file was generated and the ".rdd" file was not generated.
Do PNNL models generate mean air temperature for each zone? As you can see in the attached photo, the outside temperature can be generated but the zones mean air temperature and inside temperatures are missing.
Hello,
Hello,
Indoor Temperature Dataset of PNNL Models
Hello,
C:\fakepath\Capture.PNGmissing. image description
Hello,
I asked a question regarding the Temperature Dataset activating variables of PNNL Models and found the answer of it on this link.
Do PNNL models generate mean air temperature for each zone? As you can see in the attached photo, the outside temperature can be generated but the zones mean air temperature and inside temperatures are missing. image description
Hello,
I asked a question regarding activating variables of PNNL Models and found the answer of it on this link.
Hello,
Hello,
