I'm not sure why I'm getting the errors. I'm conducting a Parametric simulation using LHS and i require 10,000 runs of those simulations. However, I went to check the output files before completing the simulation so that I can solve those issues first.
For the RVI file, I have used the default given by the example in the jePlus v2.0 folder as shown below:
eplusout.eso eplusout.csv InteriorLights:Electricity Electricity:Building Electricity:HVAC Electricity:Plant Electricity:Facility Gas:Plant Gas:Facility 0
However, when I click into the folder for most of the simulation runs: I saw that that the energyplus program has been terminated for all of them, attributed to fatal error in processing input file. I have no idea which part it is referring too and the model that I am conducting the parametric simulation on is pretty big so its pretty hard to find out where the error came from. Can anyone please help me get through this? Help will be greatly appreciated! Let me know if you need more information from me.
