I can use OpenStudio Application 1.0.0. I defined work efficiency, air velocity, clo schedules. But I don't see PMV-PPD, Adaptive Thermal Comfort value in the Output. How can I find Thermal comfort values in Output?
| 1 | initial version |
| 2 | retagged |
I can use OpenStudio Application 1.0.0. I defined work efficiency, air velocity, clo schedules. But I don't see PMV-PPD, Adaptive Thermal Comfort value in the Output. Results. How can I find Thermal comfort values in Output? Results?
