Hello Everyone,
I work with PNNL Prototype Building Models in EnergyPlus. I need hourly indoor and outdoor temperatures in different zones. As you may know, these temperatures should be stored in the ".ESO" file in the output of EnergyPlus models.
The problem that I have is when I run these prototype models, the ".ESO" file is not generated. Should I add any parameter to the model? Do PNNL models that have been used as benchmark energy models generate hourly datasets?
FYI, I use windows and version 9.0.1 of energy plus. I tried with other versions as well, but It did not work. The PNNL sample models are on version 9.0.0. I checked other generated files, but I couldn't find any hourly temperature data.
I really appreciate any help you can provide.
