is this normal in designbuilder ?
so in a zone when i'm using a simple HVAC in design building i stimulate my projet and i get some confusing results as you can see in the photo why the outside dry air temperature in summer is less than the air temperature does that means that in summer the heating is working instead of cooling or as i can see the HVAC is not working : C:\fakepath\w.PNG
