I'm trying to better understand how the VRF system is modeled. I'm using openstudio 3.3.0. I built a "Test Model" whos geometry is a simple two room floor plan, each room is its own thermal zone.
After placing the VRF system and the VRF Zone Terminal Units, I get the following error when running the simulation.
Fatal ** GetVRFInput: Errors found in getting AirConditioner:VariableRefrigerantFlow system input. Preceding condition(s) causes termination.
I went through and tried to enter information into the input fields that were blank, but the error persist.
