I'm trying to generate an IDF file by using OpenStudio. I've already done the building 3D construction. Now, I need to configure the HVAC system of the building.
In the image here attached there's the floor plant of the building on which I'm working: C:\fakepath\Impianto Termico.PNG
The heating/cooling system is represented, as you can see, by:
- 1 outdoor unit (beacuase the other one is connected): Mitsubishi PUMY-P125YKM4;
- 3 interior units: Mitsubishi PLFY-P25 VCM-E3;
- 1 Compact wall-mounted fan heater: Vortice MICRORAPID T 1000-V0
The red pipe connects the different units.
I'm undecided about what type of HVAC system I have to create in OpenStudio, if a "Zone HVAC Equipment" or an "Air Loop System".
Is there anyone who could help me?
Besides, any other hints would be useful! Thank You!
