Hi friends, I am creating a chilled water system in Openstudio where a cooling tower is needed. Now i am dragging a cooling tower from the library which use the default parameter values and for many parameters unknown i have to set therm as autosized. is anyone know where i can find a database for the performance of cooling towers. i am not sure if this dataset is already contained in the Energyplus or Openstudio installation files,or programmed in the BCL component. Many Thanks!
