Installation problem Ubuntu 20.04 OpenStudio Application
I've downloaded the DEB package of OpenStudio App in my computer. But when I try to install it (sudo dpkg -i sudo dpkg -i OpenStudioApplication-1.0.0.4f5416cfc7-Linux.deb) it launch the following error:
dpkg: dependency problems prevent configuration of openstudioapplication-1.0.0: openstudioapplication-1.0.0 depends on libwxgtk3.0-0v5 (>= 3.0.0) | libwxgtk3.0-0 (>= 3.0.0); however: Package libwxgtk3.0-0v5 is not installed. Package libwxgtk3.0-0 is not installed.
dpkg: error processing package openstudioapplication-1.0.0 (--install): dependency problems - leaving unconfigured Errors were encountered while processing: openstudioapplication-1.0.0
So I install both packages: the first one (sudo apt-get install -y libwxgtk3.0-gtk3-0v5) launch the following warning:
libwxgtk3.0-gtk3-0v5 is already the newest version (3.0.4+dfsg-15build1). You might want to run 'apt --fix-broken install' to correct these. The following packages have unmet dependencies: openstudioapplication-1.0.0 : Depends: libwxgtk3.0-0v5 (>= 3.0.0) but it is not installable or libwxgtk3.0-0 (>= 3.0.0) but it is not installable E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
I do that (sudo apt --fix-broken install) and click 'Y' to delete OpenStudioApp.
I continue with the other package: (sudo apt-get install -y libwxgtk3.0-gtk3-0v5): and launch the following message: libwxgtk3.0-gtk3-0v5 is already the newest version (3.0.4+dfsg-15build1). The following package was automatically installed and is no longer required: libfprint-2-tod1 Use 'sudo apt autoremove' to remove it. I command the suggestion (sudo apt autoremove) and remove that package. Now I have both installed (libwxgtk3.0 and libwxgtk3.0v5), so I use again the command to install OpenStudio and again launch the same first error. Any idea why this happens?
