I'm deriving several outputs from my model to evaluate indoor air quality.
What is the difference below? There is only a slight difference in the result value.
- 'Zone Air CO2 Concentration' vs. 'AFN Node CO2 Concentration'
- 'Zone Air Generic Air Contaminant Concentration' vs. 'AFN Node Generic Air Contaminant Concentration'
- 'Zone Air Humidity Ratio' vs. 'AFN Node Humidity Ratio'
There is one more question. When setting the output variable to 'AFN node', why do I need to enter 'zone name' instead of 'surface name' in key value? Is it an error in Energyplus?
