The volume flow rate on AFN only while heating in EnergyPlus
Currently, I can get results using 'Zone Air System Sensible Heating Rate' and 'AFN Linkage Node 2 to Node 1 Volume Flow Rate' in my model in E+.
However, can I report the value of the volume flow rate only under the heating condition from the CSV file?
In other words, is it possible to report the result of the airflow rate only when the heating rate is not zero? What is the way?
