Hello,
I have installed Sketchup 2017 Make, Sketchup Pro 2020 (Trial), OpenStudio 3.0.1, and EnergyPlus 9.3.0. I am using windows 64 bit.
If I remember correctly from my previous success, the next step is to go into the extension manager and import the openstudio ruby extension. However, there is no accessible .rbx file to select in the Ruby folder under the OpenStudio folder. (I have looked elsewhere even though I know this is the right spot)
Do you have any advice?
Thank you, Cullen
