I attempted to edit the IDF file by editing the ShadowCalculation object accordingly:
ShadowCalculation, PixelCounting, !- Shading Calculation Method Periodic, !- Shading Calculation Update Frequency Method 20, !- Shading Calculation Update Frequency 15000, !- Maximum Figures in Shadow Overlap Calculations SutherlandHodgman, !- Polygon Clipping Algorithm 512; !- Pixel Counting Resolution
However, when I save the IDF file and try to import it into OpenStudio, I receive the following error:
"File is not valid to draft strictness. Check that IDF is of correct version and that all fields are valid against Energy+.idd.
The collection is INVALID at strictness level 'Draft', because of the errors: Field level data error of type DataType . Error is in an object of type 'ShadowCalculation', named '', in field 0. Additional information about the error type: field-level data is of an incorrect type. Field level data error of type NumericBound . Error is in an object of type 'ShadowCalculation', named '', in field 2. Additional information about the error type: numeric data violates a min or max bound."
Do you have any suggestions?
Thank you, Cullen
