emphasized text Hi all. I encountered a problem with openstudio 1.7.0. The installation process ended with an error message reporting that openstudio can't find sketchup installation folder, so the OS plugin cannot be installed. In some post , this problem is related to the incompatibility between different versions of openStudio and sketchup (32bit/64bit). But in my case, I have installed the 64bit version of both. Oddly, the legacy plugin installed correctly...After re-installing many times, I solve re-installing sketchup in drive C: (and not in E:). That's all, I solve changing the drive... and this can be good to know. Maybe the installer search ONLY in C: drive by default (?).
