Every time I use the OpenStudio Results Measure, no matter which model I am using, the simulation always fails. Then when I try to remove the measure, the simulation won't run as it did before. No .err file is created.
The simulation reads the following after pressing 'run':
Initializing workflow. Processing OpenStudio Measures. Translating the OpenStudio Model to EnergyPlus. Processing EnergyPlus Measures. Failed.
