As below diagram shows, heat recovery system is exchanging the heat between mixed air and conditioned air to reheat the supply air.
I tried to use openstudio to model this system, but it not allowed to put heat exchanger component on any node except the outdoor and exhaust air node.
Is there any way to model this kind of system using openstudio or energyplus?
