Hi, My question is about FMI 1.0 and 2.0. I want to couple Modelica FMU with EnergyPlus FMU. I want to link the Modelica FMU with the EnergyPlus FMU using a master algorithm such as PyFMI. In this situation, how can I select which FMI version I will use? EnergyPlus is compatible with FMI 1.0 while Modelica with FMI2.0. Is there an option in Modelica to select FMI 1.0? Thank you in advance.
