Is this measure broken?
[16:39:02.101159 WARN] Could not get data for ZoneComponentLoadSummary TZ BC2 Estimated Cooling Peak Load Components Fenestration Solar Total.
[16:39:02.103869 WARN] Could not get data for ZoneComponentLoadSummary TZ BC2 Cooling Peak Conditions Time of Peak Load Value.
Zone:TZ 100
Get Ventilation
Get Infiltration
Get Occupant
Unoccupied: 0, Lightly Occupied: 0
[16:39:02.870246 ERROR] undefined method getOutdoorAirFlowperPerson' for #<OpenStudio::Model::DesignSpecificationOutdoorAir:0x0000022e3b9a75e8>
C:/Users/Steve/AppData/Local/Temp/osmodel-1596140605-0/resources/measures/VentilationQAQC/measure.rb:239:in
block (2 levels) in run'
C:/Users/Steve/AppData/Local/Temp/osmodel-1596140605-0/resources/measures/VentilationQAQC/measure.rb:224:in each'
block in run'
C:/Users/Steve/AppData/Local/Temp/osmodel-1596140605-0/resources/measures/VentilationQAQC/measure.rb:141:in each'
run'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:514:in apply_measure'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:109:in
block in apply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:in each_index'
apply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/jobs/run_reporting_measures.rb:105:in perform'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:in
step'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:234:in run'
:/openstudio_cli.rb:973:in
execute'
:/openstudio_cli.rb:763:in execute'
:/openstudio_cli.rb:1757:in
<main>'
eval:149:in eval'
eval:149:in
require_embedded_absolute'
eval:123:in block in require'
eval:117:in
each'
eval:117:in require'
eval:3:in
<main>'
[16:39:02.872974 ERROR] :/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb failed with message Runner error :/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb failed with undefined method getOutdoorAirFlowperPerson' for #<OpenStudio::Model::DesignSpecificationOutdoorAir:0x0000022e3b9a75e8>, C:/Users/Steve/AppData/Local/Temp/osmodel-1596140605-0/resources/measures/VentilationQAQC/measure.rb:239:in
block in run'
run'
apply_measures'
step'
execute'
<main>'
eval:149:in eval'
eval:149:in
eval:117:in
each'
eval:3:in
<main>' in :/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:538:in rescue in apply_measure'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:498:in
apply_measure'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:109:in block in apply_measures'
each_index'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:in apply_measures'
perform'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:in step'
run'
:/openstudio_cli.rb:973:in execute'
execute'
:/openstudio_cli.rb:1757:in <main>'
eval:149:in
eval'
eval:149:in require_embedded_absolute'
eval:123:in
block in require'
eval:117:in each'
eval:117:in
require'
eval:3:in <main>'
[16:39:02.873322 ERROR] Found error in state 'reporting_measures' with message [":/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb failed with message Runner error :/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb failed with undefined method
getOutdoorAirFlowperPerson' for #<openstudio::model::designspecificationoutdoorair:0x0000022e3b9a75e8>, C:/Users/Steve/AppData/Local/Temp/osmodel-1596140605-0/resources/measures/VentilationQAQC/measure.rb:239:in block (2 levels) in run'\nC:/Users/Steve/AppData/Local/Temp/osmodel-1596140605-0/resources/measures/VentilationQAQC/measure.rb:224:in
each'\nC:/Users/Steve/AppData/Local/Temp/osmodel-1596140605-0/resources/measures/VentilationQAQC/measure.rb:224:in block in run'\nC:/Users/Steve/AppData/Local/Temp/osmodel-1596140605-0/resources/measures/VentilationQAQC/measure.rb:141:in
each'\nC:/Users/Steve/AppData/Local/Temp/osmodel-1596140605-0/resources/measures/VentilationQAQC/measure.rb:141:in run'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:514:in
apply_measure'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:109:in block in apply_measures'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:in
each_index'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:in apply_measures'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/jobs/run_reporting_measures.rb:105:in
perform'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:in step'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:234:in
run'\n:/openstudio_cli.rb:973:in execute'\n:/openstudio_cli.rb:763:in
execute'\n:/openstudio_cli.rb:1757:in <main>'\neval:149:in
eval'\neval:149:in require_embedded_absolute'\neval:123:in
block in require'\neval:117:in each'\neval:117:in
require'\neval:3:in <main>' in :/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:538:in
rescue in apply_measure'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:498:in apply_measure'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:109:in
block in apply_measures'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:in each_index'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:in
apply_measures'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/jobs/run_reporting_measures.rb:105:in perform'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:in
step'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:234:in run'\n:/openstudio_cli.rb:973:in
execute'\n:/openstudio_cli.rb:763:in execute'\n:/openstudio_cli.rb:1757:in
<main>'\neval:149:in eval'\neval:149:in
require_embedded_absolute'\neval:123:in block in require'\neval:117:in
each'\neval:117:in require'\neval:3:in
<main>'::/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:647:in rescue in apply_measure'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:305:in
require'\neval:3:in `<main>'"]}
