The measure ExportVariabletoCSV in conjunction with two other measures Add Output Variable and Add Output Diagnostics were used to get the hourly data of surface average face conduction heat transfer energy. The measure ExportVariabletoCSV worked well with the simulation done in OpenStudio Application 1.0.0, although while running the same measure for a simulation in PAT 3.0.1 containing ‘n’ design alternatives resulted in the following error "No such file or directory @rb_sysopen". How could this be rectified? Error message is attached herewith for introspection.
I suspect if default part of the code attached here needs to be modified to suite the PAT simulation?
