Hi,
I'm having trouble getting the OpenStudio plugin for SketchUp to work. The closest I have been to succeeding was by:
- Installing sketchup 2019 or sketchup 2020 (I have tried both, with the same result)
 - Install OpenStudio Application 1.0.0 from GitHub
 - Download OS plugin for SU version 1.0.0 from GitHub
 - Install the plugin within SU using the extension manager
This works initially, with OpenStudio toolbars appearing and seeming to work. But when I close SketchUp and reopen it, I get the following error message and the OS toolbars no longer appear.
Error Loading File C:/Users/alang/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/OpenStudio/Startup.rb
Error: #<NoMethodError: undefined method `inspector_dialog' for nil:NilClass>
C:/Users/alang/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/openstudio/lib/interfaces/RenderingColor.rb:197:in `update_entity'
C:/Users/alang/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/openstudio/lib/interfaces/DrawingInterface.rb:173:in `draw_entity'
C:/Users/alang/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/openstudio/lib/interfaces/ModelInterface.rb:944:in `block in attach_openstudio_model'
C:/Users/alang/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/openstudio/lib/interfaces/ModelInterface.rb:942:in `each'
C:/Users/alang/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/openstudio/lib/interfaces/ModelInterface.rb:942:in `each_with_index'
C:/Users/alang/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/openstudio/lib/interfaces/ModelInterface.rb:942:in `attach_openstudio_model'
C:/Users/alang/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/openstudio/lib/ModelManager.rb:227:in `attach_openstudio_model'
C:/Users/alang/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/openstudio/lib/ModelManager.rb:177:in `open_openstudio'
C:/Users/alang/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/openstudio/lib/ModelManager.rb:142:in `new_from_path'
C:/Users/alang/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/openstudio/lib/ModelManager.rb:117:in `new_from_skp_model'
C:/Users/alang/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/openstudio/lib/PluginManager.rb:165:in `start'
C:/Users/alang/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/openstudio/lib/PluginManager.rb:544:in `<module:OpenStudio>'
C:/Users/alang/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/openstudio/lib/PluginManager.rb:87:in `<top (required)>'
C:/Users/alang/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/OpenStudio/Startup.rb:67:in `load'
C:/Users/alang/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/OpenStudio/Startup.rb:67:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:in `load'
C:/Users/alang/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/openstudio.rb:45:in `register_extension'
C:/Users/alang/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/openstudio.rb:45:in `<top (required)>'
 I have also read through discussions here and on GitHub, and tried a bunch of solutions to similar issues from the past, but with no luck. Any suggestions would be very much appreciated!
Thanks, Alan
