GLHEPRO Export Measure Issue
Openstudio 1.0.1 (and 1.0.0). When I run the measure I can see the results on the results tab but the files that are supposed to be exported (csv and gt1) to the run folder are missing. Anybody come across the same issue? Measures are updated from BCL. OSM runs fine but the output is just not there.
