Hello, I am having issue with merge with current osm option in Openstudioapplicaiton. i am using Sketchup 2019 with sketchup openstudio plugin and Openstudio application 1.0. I created the geometry and saved geometry through openstudio plugin as .osm format and tried to merge the model in openstudio application through the import osm option and merge osm in the openstudioapplication. The Openstudio just crashes with message "Unhandled expression had occured" bad cast. Any help would be appreciated. Thanks
