Greeting to everyone I'm currently trying to achieve a way with openstudio to obtain the temperature between material layers. i'm working on a thesis for my graduation related to the simulation of some tatched walls. The core of my thesis is to match the collected data with the results of the dinamic analisys. To do so i was already been able to simulate the behaviour of the test building achieving the correct inside surfae temperature and outside surface temperature. My tutor asked me to try, since he couldn't know if possible, to se the openstudio in order to obtain also the inside surfaces temperature, since the wall i need to test are composed of sevral layers of materials.
I'm honestly struggling in doing so, since i can't find a way with openstudio to place a sensor between those layers and flag an option to obtain results. I tried even the way of creating a measure, but even that seems not leading to any solution. [i have to admit i'm not used to create measures] I read this topic: https://unmethours.com/question/24177/material-surface-temperature/ But i didn't find it useful since i didn't quite understand how to proceed.
Thank you all for the attention and sorry for my poor explanation.
