When I input an .idf file into Skethcup 2019, and then make a few changes to the model, after exporting the file I try to input it again and the changes did not save. I then tried to manually code the dimensions into the .idf itself but when I uploaded it the model still looked the same, however, when I used the openstudio inspection tool the coordinates displayed the values I manually input without actually updating the model. I am using a Lenovo Thinkpad with Windows 10.
