Hi all,
We've hit a bug in our code base that will randomly add unnecessary edges/surfaces when doing surface matching. It's surprisingly inconsistent and I haven't been able to pin down why it happens.
Below is a screenshot before and after performing intersect surfaces and match surfaces. I have a ceiling plenum space touching a set of perimeter and core layout. For some reason, two extra lines are added:
I created a minimum working example with the old legacy code we use for surface matching and intersecting. The original author has long since left the project but it seems fairly simple to grasp. The code and example for regenerating this problem can be found on github here. The script you'd want to run is titled surface_matching.rb. The one edit you'd need to make is on line 48 for the path to the before_matching.osm file.
require 'openstudio'
# Helper to load a model in one line
def osload(path)
translator = OpenStudio::OSVersion::VersionTranslator.new
ospath = OpenStudio::Path.new(path)
model = translator.loadModel(ospath)
if model.empty?
raise "Path '#{path}' is not a valid path to an OpenStudio Model"
else
model = model.get
end
return model
end
def match_blocks(model)
spaces = model.getSpaces
outside_spaces = []
spaces.each do |space|
space.surfaces.each do |surface|
if (surface.outsideBoundaryCondition == "Outdoors" ||
surface.outsideBoundaryCondition == "Ground")
outside_spaces << space
break
end
end
end
n = outside_spaces.size
boundingBoxes = []
(0...n).each do |i|
boundingBoxes[i] = outside_spaces[i].transformation * outside_spaces[i].boundingBox
end
(0...n).each do |i|
(i+1...n).each do |j|
next if not boundingBoxes[i].intersects(boundingBoxes[j])
outside_spaces[i].intersectSurfaces(outside_spaces[j])
outside_spaces[i].matchSurfaces(outside_spaces[j])
end #j
end #i
end
#----- Main testing starts here
osm_path = 'C:/git/stack_overflow_questions/unmet_hours/surface_matching/before_matching.osm'
model = osload(osm_path)
# Match and intersect surfaces
match_blocks(model)
File.open("after_matching.osm", 'w') {|f| f.write(model)}
Any thoughts on what's causing this?
Thanks!
