Hi, all
I would like to size the system design supply airflow rates for my baseline case based on a supply-air-to-room-air difference (ASHRAE90.1 requirement). I think in EnergyPlus, it is realized by choosing "Temperature Difference" in the "Zone Cooling Design Supply Air Temperature Input Method" under "Sizing:Zone" section. Is it corret? If so, is there any similar function in OpenStudio? I didn't find the related function in OpenStudio.
Yan
