I have a complex model setup on Openstudio ans was hoping to run the radiance daylight measure however the model fails without any error log. All exterior windows have shading control, and all zones are linked with their corresponding illuminance maps and daylight controls. When I apply the Radiance measure I get no option for inputs and I do not understand why. I'm using sketchup 2017 and Openstudio 2.9.1.
This is my run log: Initializing workflow. Processing OpenStudio Measures. Applying RadianceMeasure Failed.
and this is the run file
[09:41:40.696622 ERROR] :/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb failed with message C:/Users/Mariam Maged/AppData/Local/Temp/OpenStudioApp.r19176/resources/measures/RadianceMeasure 1 1 1/measure.rb:1320: syntax error, unexpected '.'
t_radGlareSensorViews[space_name]&.each do |sensor, v|
C:/Users/Mariam Maged/AppData/Local/Temp/OpenStudioApp.r19176/resources/measures/RadianceMeasure 1 1 1/measure.rb:1418: syntax error, unexpected keyword_rescue, expecting keyword_end
rescue Exception => e
^ in :/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:339:in load'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:339:inapply_measure'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:109:in block in apply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:67:ineach_index'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:67:in apply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/jobs/run_os_measures.rb:68:inperform'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/run.rb:285:in step'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/run.rb:232:inrun'
:/openstudio_cli.rb:975:in execute'
:/openstudio_cli.rb:763:inexecute'
:/openstudio_cli.rb:1746:in <main>'
eval:116:ineval'
eval:116:in require_embedded_absolute'
eval:101:inblock in require'
eval:95:in each'
eval:95:inrequire'
eval:3:in <main>'
[09:41:40.696622 ERROR] Found error in state 'os_measures' with message [":/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb failed with message C:/Users/Mariam Maged/AppData/Local/Temp/OpenStudioApp.r19176/resources/measures/RadianceMeasure 1 1 1/measure.rb:1320: syntax error, unexpected '.'\n t_radGlareSensorViews[space_name]&.each do |sensor, v|\n ^\nC:/Users/Mariam Maged/AppData/Local/Temp/OpenStudioApp.r19176/resources/measures/RadianceMeasure 1 1 1/measure.rb:1418: syntax error, unexpected keyword_rescue, expecting keyword_end\n rescue Exception => e\n ^ in :/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:339:inload'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:339:in apply_measure'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:109:inblock in apply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:67:in each_index'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:67:inapply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/jobs/run_os_measures.rb:68:in perform'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/run.rb:285:instep'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/run.rb:232:in run'\n:/openstudio_cli.rb:975:inexecute'\n:/openstudio_cli.rb:763:in execute'\n:/openstudio_cli.rb:1746:in<main>'\neval:116:in eval'\neval:116:inrequire_embedded_absolute'\neval:101:in block in require'\neval:95:ineach'\neval:95:in require'\neval:3:in<main>'::/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:639:in rescue in apply_measure'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:645:inapply_measure'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:109:in block in apply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:67:ineach_index'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/util/measure.rb:67:in apply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/jobs/run_os_measures.rb:68:inperform'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/run.rb:285:in step'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.4/lib/openstudio/workflow/run.rb:232:inrun'\n:/openstudio_cli.rb:975:in execute'\n:/openstudio_cli.rb:763:inexecute'\n:/openstudio_cli.rb:1746:in <main>'\neval:116:ineval'\neval:116:in require_embedded_absolute'\neval:101:inblock in require'\neval:95:in each'\neval:95:inrequire'\neval:3:in `<main>'"]}
