construction application on external horizontal surface
Hi everyone, my question is this: When applying a construction on an external horizontal surface, how do "inside" and "outside" of the construction correspond to "up" and "down" of the surface? In my case I have a balcony, which has off-white marble as coating material ("up") and plaster on the other side ("down"). How can I ascertain that the marble will be assigned "up" and plaster "down"?
Thanks
Thanks
Thanks
Thanks
Thanks
