cooling tower fan and condenser pump control method of condenser loop
When the cooling tower of the single speed and the coolant pump of the variable speed are configured in the condenser loop, the condenser pump is operated at the maximum flow rate and the cooling tower fan is reduced. On the contrary, I want to control the flow rate of the condenser pump as the cooling tower fan has increased. What should I do?
